OpenTelemetry Audit Logs
Server logs
Historically, server logs have been defined as the collection of system, rule, and audit logs within the Milestone XProtect VMS.
  • System logs: Logs created by system components focused on operational data, like errors, warnings, or con-figuration information.
  • Rule logs: Logs created when the conditions of rules created in the system by administrators are met.
  • Audit logs: Records of user and system activity used for security, compliance, and accountability purposes.
