What is ONVIF?
ONVIF® is a leading and well-recognized industry forum whose mission is to provide and promote standardized interfaces for effective interoperability of IP-based physical security products.
® ONVIF is a trademark of Onvif, Inc.
When products that conform to the same ONVIF profile are used together, systems designers and end users know that they can easily design and use a system where products will seamlessly communicate and integrate.
For detailed information about ONVIF, the organization and its full scope, check: https://www.onvif.org/
