Milestone Securitas AeroScout Integration for healthcare staff
Log in to MobileView UI from XProtect Smart Client
If you have installed the Milestone Securitas AeroScout plug-ins installed, after you log in to XProtect Smart Client with your XProtect credentials, the system prompts you to log in to MobileView UI with your AeroScout MobileView user name and password.
If you have not logged in to MobileView UI, you are asked to log in every time you open the AeroScout tab in XProtect Smart Client.
When you log in to MobileView UI, you can view the AeroScout MobileView map that is related to an alarm.
