Add an AeroScout MobileView view
With Milestone Securitas AeroScout Integration, you can view alarms from XProtect, the cameras that are associated with these alarms, maps from XProtect Smart Client, and AeroScout MobileView zones. You can add these elements as views on the View tab.
To add a view:
In the right corner, click Setup to enter setup mode.
In the Views pane, select the group you want to add the view to.
Create a new view or select an existing one.
In the System overview pane, select Securitas AeroScout and drag the wanted element into a view item. You can select to add:
AeroScout - it consists of three items: events that come from AeroScout MobileView and the cameras and maps associated with these events.
Cameras View - add to view the cameras that are related on an AeroScout MobileView event.
Events View - view events that come from AeroScout MobileView.
Maps View - view maps that are associated with events from AeroScout MobileView.
Click Setup again to exit setup mode. Your changes are saved.
