XProtect Hardening guide
Log Server
Versionver24
LanguageEnglish
Install Log Server on a separate server with SQL Server
For very large systems with many transactions to and from the log server's SQL Server database, Milestone recommends that you install the Log Server component on a separate server with its own SQL Server and store logs in a SQL Server database on that local SQL Server. If the Log Server is affected by performance issues, for example, due to flooding or other reasons, and uses the same SQL Server as the management server, both services can be affected.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 SC-7 Boundary Protection
  • NIST SP 800-53 CM-9 Configuration Management Plan
Limit the IP access to Log Server
Milestone recommends that only VMS components can contact the Log Server. Log Server uses port 22337.
  • NIST 800-53 CM-6 Configuration Settings
  • NIST 800-53 CM-7 Least Functionality
