Retrieve Edge Storage recordings on event or time schedule
Edge Storage recordings can also be retrieved on event or schedule. This is done by configuring a rule that retrieves the Edge Storage recordings on event and/or time schedule.
When retrieving remote recordings, it is possible to select to retrieve recordings from a specific time interval or a set time before the event occurred or schedule started.
The setup of the rules is done in the XProtect Management Client using the ‘Manage Rule’ wizard.
Rule example: Retrieve recordings from 7.00 to 22.00
Rule example: Retrieve last 1 hour
If the recordings need to be retrieved following a specific schedule, the rules can be configured to start based on a time profile.
