XProtect Manager Plug-in
XProtect Evidence Plugin
Version1.0
LanguageEnglish
The XProtect Evidence Plugin is an evidence-handling tool that offers XProtect users a quick and easy way to submit video files and other digital evidence to their Digital Evidence Management System. It provides a consistent operator flow across all cases of creation and desired workflows through integrations with other Digital Evidence Management Systems.
Within the user interface, you can enter a case number/ID, add metadata (i.e., classification, name, address, and more) to a configurable meta-form, and then select cameras and specify the event times of interest. The XProtect Evidence Plugin will pull the original first instance video files (block.blk) and then automatically rewrap the video file to a standard .mp4 file. It will send both files and metadata to your preferred Digital Evidence Management System.
