XProtect Manager Plug-in
About XProtect Evidence Plug-in
Version1.0
LanguageEnglish
The XProtect Evidence Plug-in is an evidence-handling tool that offers XProtect users a quick and easy way to submit video files and other digital evidence to their Digital Evidence Management System. It provides a consistent operator flow across all cases of creation and desired workflows through integrations with other Digital Evidence Management Systems.
Within the user interface, you can enter a case number/ID, add metadata (i.e., classification, name, address, and more) to a configurable meta-form, and then select cameras and specify the event times of interest. The XProtect Evidence Plug-in will pull the original first instance video files (block.blk) and then automatically rewrap the video file to a standard .mp4 file. It will send both files and metadata to your preferred Digital Evidence Management System.
