Change the date format
Select the date format that you want to appear in the Milestone Customer Dashboard interface and in the reports that you create.
In the upper right-hand corner, select your user name and select User settings.
On the User settings page, under Language and region, select the desired date format in the Date format list.
Select Save to apply the changes.
