CCure licenses
You can get the integration license from Software House and apply this license with the CCure License Manager tool.
To apply the license, you must enable the “Milestone - XProtect Corporate SDK - Integration” license option, which you can find in the Licensed Features section of the CCure 9000 tab.
Important
This license does not have anything to do with the version of XProtect ( XProtect Professional+, XProtect Expert, XProtect Corporate …etc.) used with the integration. This name merely covers the name of the license that CCure has chosen to use. Also, the license name will look slightly different between CCure version 3.0 and CCure versions 2.9 and lower. However, the name of the license is still "Milestone - XProtect Corporate SDK - Integration."
