The XProtect Management Client user interface
Why is the Processing Servers node not available?
Your IVA app integrator has connected Milestone AI Bridge to your XProtect VMS, and you have installed the Processing Server Admin plugin (VideoOS.ProcessingServer.Plugin.Admin.Installer), but there are still no Processing Servers node and Processing server tab in XProtect Management Client.
The processing server and your computer with XProtect Management Client are likely not on the same network or domain. To fix it, add the IP address and the hostname of the processing server to the hosts file on the computer with XProtect Management Client.
