Milestone AI Bridge administrator manual
License activation
If you receive video streams from your IVA applications, each video stream uses a device license. As usual, changes in the use of device licenses require license activation.
Some manufacturers of IVA applications have chosen to let you activate licenses to their IVA applications through your Milestone SLC. If this is the case, you activate your IVA applications like any XProtect license.
If a manufacturer of one or more IVA applications has chosen to have their IVA applications activated another way, contact your IVA app integrator.
