Create rules with analytics events
You can create rules with the analytics events from IVA applications as you do with any other events in your XProtect VMS.
Select Site Navigation > Rules.
Right-click Rules and select Add Rule.
Give your new rule a name and a description.
Select the rule type Perform an action on <event>.
Select event in the Edit the rule description area.
Select Analytics Events and select one of the events from your IVA applications.
Continue to select the various settings for your rule and when done select Finish.
See more about rules in the administrator manual for your XProtect VMS.
