Configure playback of gaps between recordings
You can adjust how the main timeline plays back gaps between recordings.
If, for example, all cameras in a view have no recordings in the same period, there is no need to play back the non-recordings at average speed. Therefore, the timeline is, by default, configured to skip the playback of gaps between recordings. If you want to change this behavior, you can.
在全局工具栏中,选择设置等,然后选择设置。
In the Settings window, select Timeline.
Set the Playback option to either Skip gaps or Do not skip gaps.
