Add text to a view
You can add text content to view items inside a view. For example, you might want to send a message or instructions to operators or post a work schedule for security personnel. The character limit is 1,000 characters.
  1. Select the view.
  2. 在工作区工具栏中,选择设置
  3. On the System overview pane, drag the Text element to where you want the text to appear in the relevant view item and enter the text.
  4. 再次选择设置可退出设置模式并保存修改。
To change your text after you have saved the view, select Setup again, and then select Edit text on the Properties pane.
You can insert tables from products such as Microsoft Word and Microsoft Excel, but you cannot make changes to them.
