Copy a view or view group
You can copy a view or a group with all its views and paste them to another place on the Views pane.
If you have permissions, you can also copy a private view to a shared view group, making it available to more users.
  1. В панели инструментов рабочей области выберите Настройка.
  2. Select the view or group you want to copy.
  3. At the bottom of the Views pane, select Copy , or press CTRL+C.
  4. Browse to where you want to paste the view, select Paste , or press CTRL+V.
  5. To rename the copied view or group, right-click it and select Rename .
