Create a view group
You can make it easier to find and manage your views by organizing them into groups. Your system administrator may already have set up some groups, but you can usually create your own within existing view groups.
  1. Na barra de ferramentas da área de trabalho, selecione Configuração.
  2. On the Views pane, select the Private or shared view group that you want to add a group to.
  3. At the bottom of the Views pane, select Create new group .
  4. Name the group.
  5. Selecione Configuração novamente para sair do modo de configuração e salvar suas alterações.
You can now create views within your new group.
