Only refresh live streams with motion
To reduce network bandwidth and CPU usage, you can configure XProtect Smart Client to refresh a camera view item only when motion is detected. When there is no motion, a still image from the last detected motion is shown with a gray overlay and the message No motion.
This setting can significantly reduce your computer’s CPU usage, depending on the motion detection sensitivity configured by your system administrator.
  1. Na pasku narzędzi obszaru roboczego wybierz opcję Ustawienia.
  2. Select the view and the camera view item to update only when there’s motion.
  3. On the Properties pane, select Update on motion.
    To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
  4. Wybierz opcję Konfiguracja ponownie, aby wyjść z trybu konfiguracji i zapisać zmiany.
