Viewing and recordings
라이브 또는 재생 모드에서 다양한 뷰 간에 선택 및 전환하여 XProtect Smart Client에서 비디오를 볼 수 있습니다.
If there are no views, you can create them. See Private and shared views.
If a camera has a microphone or separate microphones are added, you can listen to live or recorded audio. If a camera has a speaker, you can broadcast audio.
Video from cameras is not always recorded. Typically, recording is triggered by motion, schedules, or events. Data from devices and audio from microphones are usually recorded continuously.
If you see bounding boxes in the video, a device associated with the camera is sending metadata to the system.
