Add text to a view
You can add text content to view items inside a view. For example, you might want to send a message or instructions to operators or post a work schedule for security personnel. The character limit is 1,000 characters.
  1. Select the view.
  2. 작업 공간 도구 모음에서 설정을 선택합니다.
  3. On the System overview pane, drag the Text element to where you want the text to appear in the relevant view item and enter the text.
  4. 다시 설정을 선택하여 설정 모드를 종료하고 변경 사항을 저장합니다.
To change your text after you have saved the view, select Setup again, and then select Edit text on the Properties pane.
You can insert tables from products such as Microsoft Word and Microsoft Excel, but you cannot make changes to them.
