Sharing video with security personnel outside your organization
The best option for sharing video about incidents with people outside your organization is to make an export with the relevant video sequences.
If it is a severe incident that needs to go to court, you would generate the export with digital signatures and keep a copy of the export yourself to ensure that you have the video available after the defined retention time for all video in your XProtect VMS system. If your XProtect VMS product supports evidence locks, you can also apply evidence locks on the video showing the incident.
