Install a patch for XProtect Management Client
If your XProtect VMS is version 2022 R1 or 2022 R2, you must download and install a patch for XProtect Management Client to display licenses for IVA applications on the License information page in XProtect Management Client. You can then activate the IVA application licenses the same way as regular XProtect licenses. Not all IVA applications use this licensing scheme. If your IVA applications do not, you do not need to install the patch.
Also, you need only to install the patch on the computers with XProtect Management Client from which you want to subscribe to analytics topics and manage other administrator tasks related to the Milestone AI Bridge and IVA applications integration.
To install:
  1. Log into the computers with XProtect Management Client.
  2. Exit XProtect Management Client if the application is running.
  3. Download the patch zip file that matches the version of your XProtect VMS from https://catalog.ngc.nvidia.com/resources.
    To find the patch easily, search for XProtect.
  4. Unzip the downloaded aibridge_xprotect_patch.zip file, and from the mcactivation folder, copy the two .dll files to the C:\Program Files\Milestone\XProtect Management Client folder. Overwrite the files that are already in the folder.
Now, continue to install the Milestone XProtect Processing Server Admin Plugin. See Install the Milestone XProtect Processing Server Admin Plugin.
