Open an additional views tab
To switch between different views, you can open as many views tabs as needed in the main and detached windows.
  1. On the default tabs, select New views tab.
  2. How to open additional tabs in XProtect Smart Client.
  3. Select the view that contains the relevant video. The name of the new views tab is now the name of the view you selected.
  4. To close the additional views tab, select Close tab.
  5. How to close additional tabs in XProtect Smart Client.
You can assign shortcut keys to the opening and closing of additional views tabs. On the Settings and more menu, select Settings. Select the Keyboard tab and, finally, the Application category. Now you can assign shortcut keys for the options Close selected tab and Open a new views tab.
You can’t close the main tabs on the default menu, you can only close the additional tabs.
