View recorded video from cameras on a map
You can view recorded video from cameras in a preview window when you move your mouse over a camera icon on the map. The status information in playback mode is retrieved from the camera’s current live status.
  • You can use digital zoom and PTZ controls from the camera preview if the camera supports this. In the preview window, either select the More button and select digital zoom or use the PTZ (see Pan, tilt, and zoom in live video ) controls that appear. If you have PTZ preset postions set up for a particular camera, you can activate the preset position by selecting the preset in the preview.
  • To view all the cameras (a maximum of 25 in one view) on a map simultaneously in a floating window, click the Send all cameras to floating window icon at the top of the map title bar: Button for floating window. The icon has 4 gray squares. Under the squares is a gray camera.
If you have more than 25 cameras on a map that you send to a floating window, it will not always be the same cameras you see.
