Send cameras from a map to a floating window
To view all the cameras (a maximum of 25 in one view) on a map simultaneously in a floating window:
  1. In live or playback mode, select the map that contains the cameras you want to view in a floating window.
  2. At the top of the map title bar, select Send all cameras to floating window Button for floating window. The icon has 4 gray squares. Under the squares is a gray camera..
The floating window displays a maximum of 25 cameras in the view.
If you send more than 25 cameras on a map to a floating window, it will not always be the same cameras you see.
