Restore windows and tabs when logging in
To quickly get started with your tasks, you can restore all the windows and tabs left open when you last logged out of XProtect Smart Client.
  • When logging in and the Restore windows and tabs window opens, select if you want to restore.
Perhaps your XProtect VMS system administrator has already configured that you’re asked if you want to restore, but you can also define it yourself. See Define to restore windows and tabs when logging in.
