Log in
  1. Start XProtect Smart Client. The login window is displayed.
    Login window in XProtect Smart Client.
  2. Specify the name or address of the management server that you want to connect to.
  3. Select one of these authentication methods:
  4. Select Connect.
How long it takes to log in depends on the complexity and configuration of your organization's XProtect VMS system.
A few additional steps and questions might appear depending on the configuration of your XProtect VMS system and product extensions. See also:
If a problem occurs during login, you receive an error message. See Troubleshooting: login attempts.
