No longer allow HTTP connections
You can clear the setting that allows you to log in to an XProtect VMS system using a network protocol with a connection that use an older security model (HTTP). See Allow HTTP connections.
  1. On the global toolbar, select User menu.
  2. Select Login information.
  3. Select Clear.
  4. Select OK.
