Change the PTZ click mode
The PTZ click mode determines how you move a PTZ camera with your mouse. You can set the default PTZ click mode for a camera view item based on your preferences.
On the workspace toolbar, select Setup.
Select the view and the camera view item with a PTZ camera.
On the Properties pane, expand the PTZ click mode list and choose:
Use default: Select to use the PTZ click mode defined by your system administrator. Users can’t change this setting.
Click-to-center: Choose this if you often pan to fixed objects, such as moving from a door to a window.
Virtual joystick: Choose this if you often track moving objects.
To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
Select Setup again to exit setup mode and save your changes.
