Bandwidth, CPU, and GPU usage improvement
The best way to improve the overall performance of your XProtect VMS system and XProtect Smart Client installations is for the system administrator to configure the cameras to send multiple streams and configure your XProtect VMS system to use adaptive streaming.
The following information provides alternative ways of improving network bandwidth and CPU and GPU usage in XProtect Smart Client when you create your views.
