How alarms look on a smart map
If you have got the right permissions, you can see alarms on smart maps.
If a device triggers an alarm and the device is added to your smart map, the alarm will appear as a red circle around the device or the icon for the cluster with the device inside. See Adding, deleting, or editing devices on smart map.
The icons below show how alarms appear on a smart map, depending on whether the device triggered the alarm or if the alarm is only related to the device that triggered it.
The examples show a camera icon, but the principle is the same for all devices and clusters.
Icon |
Description |
This is a source camera: the camera that triggered the alarm. |
This is a related camera: a camera associated with the selected source camera, which triggered the alarm. This icon appears when you have selected the source camera. |
This is both a source camera and a related camera: This camera triggered an alarm, and the camera is also associated with another source camera with an alarm. This icon appears when you have selected the other source camera. |
