View video from a view with both hotspot and smart map
If you have a view with both a smart map and a hotspot view item, you can watch the video from cameras on the smart map in the hotspot view item. Each time you select a camera on the smart map, its video is shown in the hotspot view item. This method is quicker and easier than previewing the video or viewing the video in another view that has a hotspot.
Open the view with the smart map and the hotspot view item.
Find the cameras on the smart map.
Select the cameras to view video from. When you select a camera, its video is displayed in the hotspot view item.
