Activating licenses
To learn more about licenses in XProtect, see the Licensing section in the XProtect VMS Administrator manual.
You must activate a license after you:
  • Install an XProtect VMS product with a registered software license (.lic) file
  • Add hardware devices in XProtect Management Client.
  • Add or modify XProtect VMS extensions and plug-ins
  • Add Milestone Interconnect™ sites
  • Upgrade to a newer version of an XProtect VMS product, including service releases
There are several steps in the license activation process. The process takes place:
  • On the My Milestone portal
  • In XProtect Management Client
  • In Milestone Customer Dashboard
Depending on your organization, the steps may be performed by different people.
Step
Where?
What?
1 Email, Milestone Customer Dashboard
You receive an email that includes a software license code (SLC) and a software license file (.lic).
In case the original file was lost, you can get the initial .lic file from Milestone Customer Dashboard.
2 My Milestone
You register the SLC on the My Milestone portal.
In case the original link was lost, you can get a new license registration link from Milestone Customer Dashboard. See Copy or send a license registration link .
3 Milestone Customer Dashboard
You register the SLC in Milestone Customer Dashboard. See Register software license codes (SLCs) .
4 XProtect Management Client
You activate the license.
(For offline activation only) You download an .lrq file. The .lrq file must be activated in Milestone Customer Dashboard.
5 Milestone Customer Dashboard
(For offline activation only) You upload the .lrq file to Milestone Customer Dashboard and download a new .lic file. See Get a software license (.lic) file.
6 XProtect Management Client (For offline activation only)You upload the .lic file to finish the offline activation process.
