Alarms triggered by LPR
You can associate some types of alarms with events from XProtect LPR. Do the following:
- Create the match list (see Add new match lists) you want to match license plates against.
- Add and configure your LPR camera(s) (see Add LPR camera).
- In the Site Navigation pane > Alarms, right-click Alarm Definitions and select Add new to create a new alarm.
- The Alarm definition information window appears. Select the relevant properties (see Alarm definitions for LPR).
- Save your changes.
- Configure the alarm data settings for LPR (see Alarm data settings for LPR).
Except for defining Triggering events, the settings for Alarm definitions are the same for LPR as for the remaining part of the system.
To define triggering events related to LPR, select the event message to use when the alarm is triggered:
- In the Triggering event field, in the top dropdown list, decide what type of event to use for the alarm. The list offers Match lists and LPR server events (see Match lists).
- In the second dropdown list, select the specific event message to use. If you selected Match lists in the dropdown above, select a match list. If you selected LPR server, select the relevant LPR server event message:
- LPR camera connection lost
- LPR camera running
- LPR server not responding
- LPR server responding
For information about the remaining alarm definition settings, see Alarm Definitions.
In the Management Client, you must make three specific Alarm List Configuration elements available for selection in XProtect Smart Client.
These elements are used for configuring alarm lists in the Alarm Manager tab in XProtect Smart Client. The relevant elements are Object, Tag, and Type, which are essential for recognizing license plate numbers (Object) and country codes (Tag).
Do the following in the Management Client:
- In the Site Navigation > Alarms, select Alarm Data Settings.
- On the Alarm List Configuration tab, select Object, Tag, and Type and click >.
The XProtect Smart Client operator can now enable these LPR-specific elements on the Alarm Manager tab.
