How devices look on a smart map
How devices appear on a smart map change based on how close they are to each other and how much you zoom in or out. Their appearance also depend on the number of devices you've selected.
Devices near each other relative to the zoom level
When cameras and other devices are close to each other, and you zoom out, the devices are grouped in clusters and displayed visually as circular icons. The cluster icon shows the number of devices inside that cluster.
A cluster of devices on a smart map.
Devices far from each other relative to the zoom level
When you zoom in, for example, by double-clicking the cluster, you can see the individual devices and any sub-clusters.
Multiple clusters on a smart map.
Information shared by the cluster icon
If a cluster contains different types of devices, for example, cameras, input devices, and microphones, the cluster icon shows the number of devices. If a cluster contains only one type of device, the cluster shows both the type of device and the number of devices.
Two clusters, with one containing a camera icon.
Click the cluster icon to get an overview of the different types of devices in a cluster.
Overview of a cluster showing device types and the number of devices for each type.
The look of selected devices and clusters
When you select devices and clusters on smart maps, they turn blue. You can select any combination and number of devices and clusters.
If you see a cluster icon that looks this way, only some of the devices inside the cluster are selected:
A cluster that looks half blue and half black, indicating that only some devices in it are selected.
MIP element clusters
MIP elements don’t cluster with any other type of device. They only cluster with MIP elements of the same type.
  • Example 1: If an area has two cameras and one MIP element, the cluster looks as shown in the image below:
    Camera cluster with MIP element underneath it.
  • Example 2: If an area has two MIP elements of different types, no cluster appears.
MIP elements have their own layer that you can turn on or off by selecting Show or hide layers and custom overlays in the smart map toolbar.
