Milestone Husky IVO 150D revision 1
About this guide
This getting started and maintenance guide for Milestone Husky IVO is a point of reference to the Milestone Husky software and Milestone Husky hardware.
This guide describes Husky Assistant, an application that helps you install, maintain, and reconfigure your system.
About your Husky IVO unit
The Milestone Husky IVO units are designed and built on an enterprise grade server architecture with a robust x64 computing architecture, utilizing industry-standard Intel® Core™ and Xeon® processors.
In contrast to proprietary NVR appliances, which are limited by specialized, task-specific firmware, Husky IVO units operate in an open Windows IoT Enterprise or Windows Server IoT OS environment. This configuration establishes the unit as a flexible, multi-purpose server, capable of supporting complex IT functions, including database management, Microsoft Windows applications, and IoT metadata processing.
The Husky IVO product range offers a scalable and adaptable platform for modern integrated technology environments, with many models featuring server-grade redundancy measures, such as RAID arrays and dual power supply, alongside a flexible operating system.
