BriefCam White Papers
Face Recognition Alerts
Version2024r2
LanguageEnglish
You can trigger rule-based alerts by face recognition. The differences between the smart alert and real-times alerts are detailed in the table below. Face recognition alerts can be used for both real-time alert and smart alerts.
Note that when using the Linux-based Next-Gen engine, there is one type of alert that covers the alert types.
Smart Alerts with Linux-based Next-Gen Engine
Smart Alerts with Windows-based Classic Engine
Real-Time Alerts with Windows-based Classic Engine
Advantage
Higher accuracy in crowded scenes, longer dwell times possible, better handling of static objects, better in overhead cameras, and more accurate object counting.
More accurate because it uses more frames per object
Better in crowded scenes for face recognition because it uses face tracking instead of full body tracking
Alert time
Up to 5 seconds
30-60 seconds
Up to 5 seconds
BriefCam object type
Still image and video clip
Video clip
Still image
Available filters
All
All
Class, Face Recognition, Count (time-dependent only), Area and Line Crossing
Face recognition alerts have a cool down period of 30 seconds. This means that when an identity triggers an alert, the same identity will not trigger another alert for 30 seconds.
