Supported VMS Platforms and File Formats
BriefCam supports a wide range of VMS platforms and video file formats as listed below:
Supported Video File Formats | 264, .3GP, .ASF, .AVI, .DIVX, .DVR*, .FLV, .G64, .G64X, .GE5, .MKV, .MOV, .MP4, .RAW, .RT4, .TS, .WMV, .XBA (single & multi-stream) |
Supported Codecs | H.264, H.265/HEVC, MPEG-4, H.263 (H.265 is supported for selected VMSs and cameras) |
Supported Pixel Formats | Yuv420p and Yuvj420p |
Recommended Video Stream Resolution | Minimum CIF (352 x 240), Maximum 4K (3840 X 2160) Resolutions between archive and real-time multi-streams can be different – as long as they both have the same aspect ratio. |
Supported Resolutions of Client's Monitor Screen | The minimum supported resolution is: 1366 X 768. |
Supported VMS Platforms (supported by BriefCam Protect, Insights and Rapid REVIEW) |
