BriefCam User Guide
How large cases load
Version2025 R1
LanguageEnglish
When a large case is opened, the system loads its data in stages to maintain performance. Here's how this process works and what to expect:
  • Object limit and video loading — When opening a large case, the system doesn't simply load all objects at once. It sorts the case's requests by their most recent video date and loads videos one by one (most recent first) until adding the next video would exceed the object threshold (for example: 300,000 objects).
  • Why a case may load with fewer objects than the limit — The system loads one video at a time and stops when adding the next one would go over the limit. For example, if a case has three videos containing 100K, 120K, and 150K detected objects, only the first two will load (220K total), because adding the third would exceed the 300K limit. That's why some cases may show fewer objects than the maximum allowed.
  • Automatic Time Range filter adjustment — When not all videos can be loaded, the Time Range filter is automatically set to match the date range of the loaded videos.
    Large and Oversized cases will load with the Time Range filter automatically filtering requests, so the number of objects loaded in a case will be less than 300,000.
