BriefCam User Guide
Creating a Customized Dimension or Measure
Version2025 R1
LanguageEnglish
You can create your own custom measures and dimensions within the BriefCam dashboard. This allows you to adapt the analytics to your specific operational needs.
To start the process, do one of the following:
  • To create a customized measure, click the Create new button.
  • To copy a measure, right-click a measure and select Duplicate.
Here is an example:
  1. Right-click on the # of People in Specific Source measure.
  2. Click Duplicate.
  3. Right-click on the newly created # of People in Specific Source (1) measure.
  4. Click Edit.
  5. Rename it to # of People in Mall.
  6. Click the Expression icon.
  7. Change 'SourceExample' to the name of one of your sources, such as 'MallEntrance'.
  8. Click Save.
You now have a customized measure that you can use across your dashboards.
