BriefCam User Guide
Showing or Hiding Specific RESEARCH Dashboards Per User
Version2024r2
LanguageEnglish
Research-Editors can determine who can see a dashboard. You do this as follows:
  1. Open the properties of a dashboard (Sheet properties).
  2. In the Show condition field, enter an expression using the example syntax below.
    • To hide a dashboard for one user named Frank: =if (UserId='frank' ,0,1)
    • To show the dashboard for one user named Frank: =if (UserId='frank' ,1,0)
    • To hide the sheet for multiple users: =if ((UserId='frank') or (UserId='dorothy') or (UserId='eli'),0,1)
Note
The usernames and group names should be written in lower case only.
