BriefCam User Guide
Setting a Specific Source and Custom Dimension
Version2024r2
LanguageEnglish
  1. When using a measure that has the words “in Specific Source” and/or “in Custom Dimensions” in the name, you need to set the source and custom dimension that you want this measure to use. You do this as follows:
  2. Drag the measure onto the dashboard, such as # of Objects in Specific Source and Custom Dimensions.
  3. Unlink the measure by clicking the unlink (Unlink icon.png) icon.
  4. Click OK.
  5. In the Expression field, click the function (Expression icon.png) button.
  6. Depending on what appears in the expression for the measure (whether it includes sources and/or custom dimensions), replace the string SourceExample with the requested source name and/or the string CustomDimensionsExample with the requested area, path, or line crossing.
    For example:
  7. Click Apply.
