BriefCam User Guide
Adding Dimensions and Measures
Version2024r2
LanguageEnglish
Once a visualization (bar chart, pie chart, etc.) has been added, you should complete it by selecting the relevant measures and dimensions from the Master items menu.
A visualization consists of at least one measure or one dimension; in most cases, a visualization has both, and sometimes it has more than one dimension or measure.
See also:
Adding Dimensions
Adding Measures
Creating a Customized Dimension or Measure
