What should I do if the license becomes broken?
Sometimes the license becomes broken due to HASP driver issues. One reason this might occur is because of a Windows update. In this case, you need to reinstall the driver manually:
Download the HASPDINST driver installer from here: https://www.dropbox.com/s/2k9x4p18uxu7p2f/haspdinst.exe?dl=0
Save the driver installer on the relevant BriefCam machine (the one(s) with the remote license issue).
Run CMD as admin and navigate to the
haspdinstfolder.Run the
haspdinst.exefile with-r -purgeto remove it:haspdinst.exe -r -purge.Run the
haspdinst.exefile again but this time with-ito install it:haspdinst.exe -i.Verify that you can access: http://localhost:1947.
