BriefCam Troubleshooting Guide
Why am I seeing the following warning in the Fetching log: Failed to retrieve directory with InternalId?
Version2024r2
LanguageEnglish
After upgrading a system, the services might start in the wrong order, which could cause the fetching from the VMS to fail.
The failure appears as the following in the Fetching Service log:
2020-01-27 15:13:09,545 [6] WARN - GLOBAL GLOBAL Handled exception. message: Failed to retrieve directory with InternalId: 1. Exception type: System.Collections.Generic.KeyNotFoundException. Exception message: The given key was not present in the dictionary..
To resolve this issue:
  • Open the Windows services and restart the following services: VSService, Redis and the World Wide Web Publishing Service (IIS) by right-clicking on the services and clicking Restart).
