BriefCam Installation Guide
Supported NVIDIA GPU Hardware
Version2025r1
LanguageEnglish
The following GPUs have undergone thorough testing by BriefCam accompanied by throughput benchmarking conducted by our organization. The results are as follows (for 1080p cameras, 15 FPS, and medium activity):
Engine
GPU
Real-time channels
On-demand Hs/H
Notes
Windows-based OX5 engine
Ampere A10
30
20
For cloud environments
Ampere A2000 / Ada RTX 2000
23
25
Ampere A4000 / Ada RTX 4000
30
28
Ada RTX4080
28
24
For laptops only
Ada NVIDIA L4
30
30
For server-grade environments
Ampere RTX A1000
From v2025 R1 SP1
Blackwell 4000 Pro GPU
From v2025 R1 SP2
Note that:
  • Other GPUs from the Ada, Ampere, and Blackwell architectures may be compatible but were not tested for function or throughput. Due to the driver and CUDA library upgrades as part of the v2025 R1 SP2 release, GPUs based on older architectures will no longer function.
  • Hs/H means the number of hours of video that can be processed in a single hour. For example, 8 Hs/H means that 8 hours of video fetched from a particular camera can be processed in 1 hour.
  • Throughput refers to number of concurrent on-demand processing speed multiplier or real-time channels per GPU (pending available GPU RAM).
  • Intel, AMD or any other non-NVIDIA GPUs are not supported.
  • BriefCam does not support using more than one models of GPU on the same machine.
