BriefCam Installation Guide
Supported NVIDIA GPU Hardware
Version2024r2
LanguageEnglish
The following GPUs have undergone thorough testing by BriefCam accompanied by throughput benchmarking conducted by our organization. The results are as follows (for 1080p cameras, 15 FPS, and medium activity):
Engine
GPU
Real-time channels
On-demand Hs/H
Windows-based OX5 engine
Ampere A10
30
20
Ampere RTX A2000
23
25
Ampere RTX A4000
30
28
Ada RTX4080 (for laptops only)
28
24
Ada L4
30
30
Note that:
  • Hs/H means the number of hours of video that can be processed in a single hour. For example, 8 Hs/H means that 8 hours of video fetched from a particular camera can be processed in 1 hour.
  • Throughput refers to number of concurrent on-demand processing speed multiplier or real-time channels per GPU (pending available GPU RAM).
  • Intel, AMD or any other non-NVIDIA GPUs are not supported.
  • BriefCam does not support using more than one models of GPU on the same machine.
