BriefCam Installation Guide
Check Prerequisites Tool
Version2024r2
LanguageEnglish
The Check Prerequisites tool checks that the hardware and operating system parameters on a machine meet the BriefCam's prerequisites before running the BriefCam installers.
The Check Prerequisites tool (BriefCamCheckPrerequisites) is available for download from BriefCam’s Installation Downloads page. From the Select Product list, select Additional Tools and then select the relevant BriefCam version.
Run the .exe file, select the components that you will be installing on the machine, and click Run.
The tool presents you with a list of the minimum prerequisites checked and you whether your machine meets the minimum prerequisites.
