Disabling Features
Face Recognition
To disable the Face Recognition feature in the REVIEW and RESPOND modules, set the clientEnableFaceRecognition environment setting to false.
To disable the Face Recognition engine, set the MetaData.EnableFaceRecognition environment setting to false.
To disable the Face Recognition feature in the RESEARCH module, set the BIFaceRecognition.RESEARCHEnableFaceRecognition environment setting to false.
License Plate Recognition
To disable the License Plate Recognition (LPR) feature, set the EnableLpr environment setting to false. This setting disables the LPR feature in the user interface and the RESEARCH platform.
Drag and Drop
To disable the drag-and-drop functionality in the client, set the clientDisableDragAndDrop environment setting to true.
Caution
This functionality is not applicable for the Hub. It is only relevant for sites and in standalone deployments.
