BriefCam Administrator Guide
Enabling the Map View
You can add a Map view to the REVIEW and RESPOND modules. In the Map view, case and non-case cameras and files are displayed on a map with easy access to the detected objects and quick addition of cameras to the case.Map View
Note that this feature is enabled by integrating with MapBox's map service. MapBox is a pay-as-you-go service above a certain free usage cap. The free usage cap is 50K monthly map loads and 100K monthly searches, which should be more than sufficient for most BriefCam uses. There is no need to add a credit card to open a MapBox account. See MapBox pricing for pricing information, and specifically for the following modules: MapBox GL JS and Temporary Geocoding API.
Note that a map load occurs whenever a map is initialized on a webpage, including every time a user reloads a page. The maximum session length for a map load is 12 hours. If a user has the same map open after 12 hours, that will count as a new map load session. It's important to note that an interaction with the map does not count towards map loads (source: https://docs.mapbox.com/help/glossary/map-loads/).
To enable the Map view:
  1. Create a business account in MapBox (https://account.mapbox.com/).
  2. In MapBox, create an access token.
  3. Paste the token in the BriefCam Administrator Console’s MapAccessToken environment setting.
  4. Set the enableMap environment setting to true.
  5. Optional. You can set the REVIEW module to open by default in Map view by setting the isMapDefaultViewInReview environment setting to true.
  6. Set the GIS coordinates by either:
    • Clicking the Geolocation icon Geolocation icon.png for each camera in the BriefCam Administrator Console. For additional information, see the Camera Configuration section.Camera Configuration
    • Clicking the Add Coordinates Map add coordinates icon1.png icon in the BriefCam client.
